02-02-2018 07:23 AM
Hi All
I've generated the INF for my USB controlled which many years successfully used under WinXP & Win7. But I can't use one under Win10 due to generated INF is not signed (see screenshot)!!!
How can it be? The VISA is signed and any USB under VISA also must be signed. Does it mean that any subclass devices under NI VISA are unusable under Win10? Or what I'm doing wrong?
Thanks in advance
02-02-2018 08:39 AM
Hi OlegUA,
I had this same issue a while back and used this KB to resolve it:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L9QSAU
It's for Windows 8 but the same steps worked on my Windows 10 PC.
02-02-2018 10:00 AM
I don't think this is a LabVIEW (or VISA) issue. Not all devices (or Device Drivers) are compatible with all Operating Systems. When you plug a new device into your Computer, Windows has to know how to communicate with it, which it does with Device Drivers. Third-party hardware uses third-party Device Drivers ...
02-02-2018 01:10 PM
Thanks a lot!
It looks like detailed instruction for dummies how to certify any driver 🙂 It is the really useful link, thanks. I'll try it on next computer due to I've resolved it by using workaround that disables checking drivers signature verification by windows command bcdedit.exe /set nointegritychecks on
Best regards
02-02-2018 01:16 PM
You aren't right. Any pseudo-driver generated by the wizard is just subclass the same VISA driver. You don't install any additional .sys, .dll, etc. We're using the same VISA system files every time when windows found specified USB PID that was mapped via .INF. Windows don't have any relations how VISA drivers inside work.
Oleg
02-12-2018 12:06 PM
wrote:
Hi OlegUA,
Hi sirknoxalot,
Could you say me which version of windows did you use? X86 or X64? I'm always getting the same error about unavailability to store driver. The windows event log contains following:
Fault bucket , type 0 Event Name: PnPDriverImportError Response: Not available Cab Id: 0 Problem signature: P1: x64 P2: E0000247 P3: ccd_usb.inf P4: e227708147346477cf1849f2e697a52fc238d6de P5: P6: P7: P8: P9: P10: Attached files: These files may be available here: C:\ProgramData\Microsoft\Windows\WER\ReportQueue\NonCritical_x64_4c6db6bf4664d2532c4e68fa7879375c43a5e9b9_00000000_156d58d2 Analysis symbol: Rechecking for solution: 0 Report Id: 47b59009-f8e1-415d-8240-6002ca0fe807 Report Status: 4100 Hashed bucket:
It seems like that .cat file is mismatch to x64 windows.
02-13-2018 02:50 AM
Also, I've found this https://blogs.msdn.microsoft.com/windows_hardware_certification/2016/07/26/driver-signing-changes-in...
As I understood, nobody can use VISA generated drivers in the future. It would be great if authorized people from National Instrument let me an explanation what I have to do with more than 15 years of my work? Do I put all my programs in the trash can? I have several very important devices that are working via VISA USB and I don't know how I will continue to use these devices under Win10 without support from NI.
I guess that NI can provide the appropriate modification of the Driver Wizard that should generate already signed by NI device drivers. They have all needed certificates that always installed on every machine. Also, I'm sure that such big company as NI already has all specific Microsoft's subscriptions and can provide an easy way to avoid the Extended Validation (EV) Code Signing Certificate for generated drivers.
I hope the NI engineers also read this forum and might be to participate in a discussion.
Oleg
02-13-2018 05:00 PM
Hi Oleg and all,
NI engineer here. NI is aware of this issue, that beginning with Windows 10 all kernel mode drivers need to be signed by Microsoft. This is a change that Microsoft has implemented and is supposed to make the signing more secure and reduce the risk of code signatures being stolen.
There are two main options to install the driver you create with the Driver Wizard:
1) Certify your driver using the workarounds in the document we've provided, Using a *.inf File from the Driver Development Wizard on Windows 8. While the title says Windows 8, you can follow the same procedure in Windows 10. Note that if you're intending to create and distribute drivers you will almost certainly have to contact a Certificate Authority and pay a fee to certify your driver. If you're creating a driver for personal use you can create a personal certificate to sign the drivers for free.
2) Disable Windows driver enforcement on your computer.
I understand that it may be annoying to have to use workarounds with a new operating system. The issue isn't one of compatibility between VISA and Microsoft, but rather Microsoft's specific decision to drivers to be signed. Unfortunately, the onus is really on Microsoft for implementing this new requirement.
02-15-2018 06:18 AM
@francine.p
Francine, thanks a lot for participating in this thread.
@francine.p1) Certify your driver using the workarounds in the document we've provided, Using a *.inf File from the Driver Development Wizard on Windows 8. While the title says Windows 8, you can follow the same procedure in Windows 10. Note that if you're intending to create and distribute drivers you will almost certainly have to contact a Certificate Authority and pay a fee to certify your driver. If you're creating a driver for personal use you can create a personal certificate to sign the drivers for free.
But unfortunately, after latest Windows updates this method is working only when option testsigning is on. So it is just workaround but not solution 😞 now all drivers should be certified by Microsoft.I don't see any other ways...
And, I've found a more detailed document about signing drivers (see attachment), maybe it also will be useful for someone.
@francine.p2) Disable Windows driver enforcement on your computer.
The second way is working very short time and cleaned up after any updates or reboot. If anybody knows how it can be disabled permanently please describe steps here.
Oleg
11-14-2018 06:14 PM
Does National Instruments have an update or a solution for resolving this issue with Windows 10 signing that doesn't involve the two options suggested?
