I'm trying to connect to an industrial wireless modem that responds to the standard AT modem command set. I've had no trouble whatsoever communicating with this device using Windows HyperTerminal connection; however, when I try to communicate with the device using LabVIEW I continuously get an error when writing to the device (sending commands). The device is a USB device; however, the manufacturers drivers configure it to be seen as a serial device in Windows. As a result, I've been using the VISA serial vi's.
To give a easy example, if I use the example vi "Basic Serial Write and Read.vi" as found in the LabVIEW help, I can open a serial connection using the following settings:
baud rate: 230400
data bits: 8
parity: NONE
stop bits: 1.0
flow control: NONE
delay: 500 ms
The error is returned when I try to send a basic command to the device. The returned error is "-1073807298" which occurs at the error out of the "VISA write" vi. If I monitor the activity at the serial port while running this vi, everything works as expected and I see the connection open; however, when LabVIEW writes to the port the following error is displayed in the port monitor "IRP_MJ_FLUSH_BUFFERS" immediately after the string is sent to the port.
To test the communications more fully, I also looked at the com port/serial device status in MAX and using the same setting, MAX validates that it works correctly. However, if I open the VISA test panel in MAX, and test the write function in the test panel I get the following error "BFFF003E".
My only idea is that part of the VISA write vi incorporates a buffer flush that HyperTerminal does not do and this buffer flush is not supported by the device. If someone can provide even a little insight into a potential problem and how I can go about fixing it, it would be greatly appreciated. Thank you very much for the help.
-Justin
