04-20-2012 08:42 AM
VISA Find Resource returns an array of strings. When I wire one of the elements to VISA Open there is a coercion dot.
Is there a function that should be use so that the coercion dot goes away?
Solved! Go to Solution.
04-20-2012 08:57 AM
Try attached. You can ignore the dot in this case as well.
04-20-2012 09:52 AM
Thanks. Keep forgeting about TypeCast.
04-20-2012 09:56 AM
That is not necessary. Wire the string directly and ignore the coercion dot. It causes no harm at all and is probably more efficient.
04-20-2012 11:06 AM
I agree with that.
04-20-2012 01:27 PM
What about using the conversion VI here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Default-Data-Function/idc-p/1084787#M4535
I think it'd be safer than using the typecast, but I'm not sure about any speed difference.
