VISA_ARDUNO_CHANNEL WIRES
@yamelbio wrote:
It is posible to 'force' an event to occur? I mean to make it happend even if the event does not really happend....maybe with a feedback or something.
As in causing an Event Structure to do something?  Look into User Events.
Message 11 of 27
(1,886 Views)
I mean triggering an existing event case.
Message 12 of 27
(1,876 Views)
Depending on what is going on in the rest of your code, it is certainly possible to simulate an Event.  There are a number of ways to do this, but the question is so vague it is difficult to know where to start in order to answer it.
Here is one approach:  Suppose you have an Event based on, say, the User pressing a Front Panel button (say "Go").  You have code in the Event Loop under the "Go, Value Changed" Event.  You could create a User Event called "Simulate Go" and put it in a timing loop to "fire" its Event every 20 seconds.  You'd wire the "Simulate Go" Event case exactly as you wired the "Go, Value Changed" case -- whatever you did in one, you'd do in the other (unless, of course, it said "Stop the Event Loop!").
Message 13 of 27
(1,874 Views)
That's exactly what I am talking about! Thanks everybody! Thanks Bob.
If I may ask, when I work more and spent hours on my program can I show you? I am surely gonna need help to improve the code...
Message 14 of 27
(1,867 Views)
Bob Schor what about event messenger? I tried that and It works! Do you suggest me that?
Message 15 of 27
(1,841 Views)
I am always reluctant to venture an opinion without seeing and understanding the problem.  I do not know what you really want to do, and I don't have (all of) the code you are using to try to accomplish your goals.  So I cannot (and should not) make any comments.
Message 16 of 27
(1,834 Views)
In labview examples, I see they use Event Messenger(EM) as the way to send information from a 1 or more producers to 1 or more event cases.
So, what I want?:
To use EM to trigger user events some time (I dont necessarily need that right now), I am just studying that.
Instead of create-generate events like Labview user events examples, I wonder if I can use EM. Thats it
Message 17 of 27
(1,830 Views)
Hi Bob Schor. Please let me ask you something: it is possible to implement a state machine using Channel Message Handler?
I have added a feedback in the while cicle that gets the "Message" to its own input, like the examples that you showed before. That can be considered a state machine? It would work?
Message 18 of 27
(1,788 Views)
I am sorry I did saw that you posted right here aun example of Channel State Machine.
My question would be if this is a good way to Do that?
That is the event loop that feeds the handler loop.
That is the handler loop that have a feedback simulating a State Machine.
That is possible?
Message 19 of 27
(1,783 Views)
I rarely look at pictures of code.  I can't see "the whole picture", I can't edit the code, I can't try to run the code, I can't fix the code.
Attach VIs, please.
Message 20 of 27
(1,765 Views)
