01-07-2022 12:56 PM
Starting here : https://www.ni.com/en-us/support/downloads/tools-network/download.ftdi-driver-for-i2c-spi-gpio.html#...
VIPM even run as administrator will not install package.
Error below: (admin mode) install failed. No admin try was no error and no install.
Main Package Name: FTDI Driver for I2C SPI GPIO v1.0.0.31
Package Name with Error: FTDI Driver for I2C SPI GPIO v1.0.0.31
Error Message: VIPM could not install the package aj_lv_ftdi_driver_for_i2c_spi_gpio-1.0.0.31 .
Error Code: 1003
Error Source: Invoke Node in D5566ECD6962606ED717A0810948FA29->0AF9339C77424DFA92DA38FDE74DE74C->4E1CC4C6560AE3803601B09E181DEFA6->OGPM Class.lvlib:89AC7BADF759B8183E200C1F7AFA7855->OGPM Class.lvlib:3617A98EB64CF6012064A2A881466B07->579BE417495B7ADCD1FF111EE165D832->VIPM Main Window.vi
<APPEND>
Method Name: Run VI
VI Path: C:\Users\........\AppData\Local\Temp\PostInstall.vi
Any idea what to try next?
01-07-2022 09:51 PM
You don't say anything about your system, so I don't know if my experience is appropriate, but I was unable to reproduce your experience.
I have a Windows 10 (64-bit) PC with LabVIEW 2021 (32-bit) installed. I did not have the FTDI Driver for I2C SPI GPIO installed. Here's my experience:
After this, I opened LabVIEW, and opened a blank VI. In the Block Diagram view, I could find a FTDI LabVIEW Driver Library in the "AddOns" Palette.
I should mention that I am running LabVIEW Professional, and have installed the LabVIEW Real-Time Module and "ordinary" LabVIEW Drivers (DAQmx, VISA, PXI Platform Services).
Based (solely) on my own experience, there seems to be nothing complicated or problematic in installing the FTDI package using VIPM with a PC having LabVIEW 2021 (32-bit) installed. My suspicion is that your LabVIEW installation is faulty.
Repairing a LabVIEW installation is fraught with difficulty. I've tried many times (starting with LabVIEW 7 and "giving up" around LabVIEW 2015) to do such a "repair", rarely with success. I now do the following:
01-08-2022 11:11 AM
Hello Bob,
Thanks for all the great ideas. My system has LabVIEW, VIPM 2019 64 bit. I also tried older system with LabVIEW 2016 64 bit and VPIM 2019 and that one errors at the beginning then acts like it is installing then no errors at end. I'm sure the problem in on my local PC's. I'll try the steps you suggested.
01-09-2022 06:55 AM
There is a very good chance that the VIPM package is not prepared to deal with LabVIEW 64-bit. Unfortunately VIPM doesn't provide very good ways to do this as you can only select if the whole package is either 32-bit or 64-bit or bit independent but not that individual files should or shouldn't be installed on a specific bitness platform.
01-11-2022 12:36 PM
I found another driver from ovak technologies that claimed to install correctly. It even said D2XX driver and VCP driver installed.
However COM3 is a resource option but no sign of 2XX being a resource.
I'm more than happy to just send an receive characters on a fake COM port. However, I have no info on using VCP commands via COM port. I'll start a new post that that.
