VI with .NET runs in Dev environment, builds, but doesn't work in runtime
I'm using the Watlow F4T drivers to control a thermal chamber. Watlow provides LabVIEW drivers and at their heart is a .NET .dll. My application runs just fine in the development environment. I created a build spec and it builds just fine. I can run the .exe in simulate mode (bypasses the Watlow drivers) with no problem. When I run the .exe with the Watlow drivers, the .exe crashes with an unknown exception. It's clearly related to the Watlow drivers (runs fine in sim mode).
In the build spec, I put the .dll in the "Always Included" category. Are there other caveats with .NET when building executables?
LV2016, 32 bit
Message 1 of 12
(1,622 Views)
The driver i downloaded is not .dll based.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0150785855373A2DE0440003BA7CCD...
But I'm using LV2012. Not sure about LV2015/2016. Maybe they are different.
Joseph
Message 2 of 12
(1,580 Views)
I downloaded the latest driver for a look-see. I don't have LabVIEW access at the moment but I can see that the package does not contain a custom .NET dll in the zip. If there are .NET calls  as you say then can you indicate what assembly they are statically linked to?
Message 3 of 12
(1,575 Views)
Try placing the dll in the .exe folder.
/Y
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 4 of 12
(1,562 Views)
Is the driver joezhang downloaded the driver we are talking about, or did you download a different one?
Chase
NI Technical Support Engineer
Message 5 of 12
(1,547 Views)
Did you try using this method to enable .NET 4.0 not on your LabVIEW.exe, but creating a "Whatever.exe.config" for your build executable?
Message 6 of 12
(1,542 Views)
Attached is the driver I am using.
Message 7 of 12
(1,535 Views)
I'm using LV2016, so it uses CLR 4.0 and thus up to .NET 4.5. I'm not able to tell if the Watlow drivers point to an earlier .NET version. The link does say that assemblies pointing to earlier versions may not work with CLR 4.0.
Message 8 of 12
(1,532 Views)
I'm having the same issue.  I can run the driver just fine in the labview environment but when I build the application, it crashed.
I tried to move their dll to the exe but that didn't help.
Was this issue resolved?  If so, could you provide a quick overview of the solution?
Message 9 of 12
(1,309 Views)
I ran out of time trying to figure it out so I switched to Modbus. I plan to revisit soon but can't say when.
Message 10 of 12
(1,298 Views)
