VI that calculates sum of random numbers
Well, there is also data queue ptbypt. These solutions all suffer from the fact that with each insertion all queued elements need to be moved in memory (or the compiler needs to track the rotation in some other way or use some extra scratch memory). Much more effort compared to just blindly overwriting the oldest element as I did, operating fully in-place. 😄
Message 11 of 16
(1,632 Views)
@RTSLVU wrote:
How about something like this?
I strongly believe that shift registers resized to more than one left node should not be taught. I never use them.
In any case, these indicators probably belong after the loop, not inside. 😉
While we are doing silly code, here's another (probably) bad idea. 😄
Message 12 of 16
(1,627 Views)
I like your first idea better with the array replacement, I assume this is the same as the array subset idea expressed earlier. Surprised at the nitpicking you are getting. If you really want to nitpick, for a random number between 0-99, the max iterations you can do is about 43 million before you overflow the i32 sum (2^31/50). Future proof and change to an i64. Smiley Very Happy
mcduff
Message 13 of 16
(1,622 Views)
Yes, I'd definitely go with my first suggestion and I even mentioned the potential need for I64. We would gain yet another bit going to U64. 😄
(I would probably add a final rotation to ensure the five elements are in sequential order)
Message 14 of 16
(1,615 Views)
can you send this?
Message 15 of 16
(1,293 Views)
Wrongly Posted
Message 16 of 16
(1,266 Views)
