01-10-2019 10:52 AM
What is the compiled code complexity? Most likely it is doing a recompile after your code changes (no matter how minor). If the diagram is large and contains many inlined subVIs, this can be expensive. Do you separate compiled code?
01-10-2019 11:14 AM
Good point Christian!
Wasn't there an issue with an earlier version of LV where code changes were extremely slow as long as the project was open?
Q
Does it save faster if you just work with the VIs open and not the project?
What version of LV are you using?
Do you have "auto-populating folders" turned on?
Ben
