VI running very slow!!
There are many things you do every iteration which only needs to be done once, and thus should be placed outside the loop completely.
- The read file is already mentioned
- The initializations of the graphs.
(- simulation?)
- Calculation for simulation
- Why do you build 3 arrays in the top left loop when you only use 2?
- The loop subtraction thingy is the same as wiring both arrays to a subtract.
I have a strong feeling the file read comsumes teh biggest portion of the time, move that outside the loop to start with.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 18
(3,154 Views)
My latest VI is attached. Read/Write spreadsheet as well Build table VI has been replaced with shift registers. As you can see, the speed didn't improve at all.
Yamaeda, the array subtraction in loop is for a reason. You can notice that a Select condition has been wired to the 'N' terminal of for loop.
Awais
Message 12 of 18
(3,149 Views)
another thing is that you refreshx scale of yx graph each iteration that take a while
may be you could refresh 1 tiem out of 10 for example
or use defer option
another way could be to create a diplay loop with producer consumer design
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 13 of 18
(3,145 Views)
Accepted by awais.h
Just for a test put this block outside  the loop you will see the loop running faster
Tinnitus
Message 14 of 18
(3,138 Views)
I just tested moving the Graph property settings to outside the loop so it only initializes once, and the loop time changed from ~50 to 1 ! ms.
/Y
Qestit Systems
Message 15 of 18
(3,114 Views)
Btw, your select case -> loop with subtraction = Arrays wired to a subtraction. Try it. 😉
Your phase filtering is abit strange, you compare to (-)310 but the booleans are named >360 and similar. Though, i'm not quite sure what you're after in that calculation. You should be able to condense it through a case structure and/or Quotient/remainder calc though.
/Y
Qestit Systems
Message 16 of 18
(3,108 Views)
"Graph property settings  outside the loop so it only initializes once"
Yes, it was a suggestion only to highlight there is something to do with this block
now it stay to know how to manage it...
Tinnitus
Message 17 of 18
(3,101 Views)
Tinnitus,
Yes, I placed the graph property node outside the loop and my VI runs perfectly. I am getting 50 results in one second just like an ideal case.
Than you very much for pointing this out.
Thank you everyone for great suggestions.
Kudos for Everybody Smiley Happy
Awais
Message 18 of 18
(3,060 Views)
