VI only runs with probe
Because of a "lucky" problem in the experiment, we managed to find a possible source for the problem. As it seems the reading rate of our force sensor, that we need to control the process, is to high and overloads the VI.
Now my question is if anyone knows of a way to make the VI more efficient, so that it accepts higher reading rates?
Message 11 of 12
(409 Views)
Hi Rhazal,
how can we help on this question? We lack all needed information!
You only attached some snippets showing the usage of some device driver VIs in conjunction with some FGVs. And you didn't name the manufacturer of your force sensor nor where you got those subVIs from...
Did you check the manual for that sensor? What's the maximum sample rate it supports?
Did you check the programming manual for those subVIs? What kind of interface to they support? At which speed? Which latency?
Message 12 of 12
(386 Views)
