VI for PXI 6052E with SCXI 1140
I am novice at LabVIEW and I am in deep need for some guidance. I have got a PXI/SCXI system that I intend to use as a multi-channel oscilloscope. I have got eight SCXI 1140 cards along with one PXI 6052E, all sitting in a PXI-SCXI combination chassis (PXI-1011), and they are being controlled by an NI 8174 controller. All the hardware has been installed properly and NI-DAQ detects everything fine. Now I want to write a VI (I have got NI-DAQ 6.9.1 and LabVIEW 6i) that will allow me to monitor my 64 anolog inputs just like in a 64 channel oscilloscope. I know that the gain on the SCXI is set manually. The reason I went with the SCXI 1140 was to have no skew time and also have differential inputs. I intend to measure 64 signals in a ran
ge of +/-100 mV at an effective sampling rate of 5KHz (for each channel)with the highest resolution possible. If you could give me any suggestion about how to write a VI for this application, I would really appreciate it. Thank you!
(3,047 Views)
Well, start with the example VIs included with LabVIEW and work from there. That's your best bet for starters.
(3,047 Views)
Hello;
The best start point for you is the Labview shipping examples for SCXI-1140.
You can find those at C:\Program Files\National Instruments\LabVIEW 6\Examples\daq\scxi.
Hope this helps.
Filipe
(3,047 Views)
Thanks for the help!
(3,047 Views)
