When using VI analyzer it comes up with an occurance that states "The control labeled "whatever" is not a dialog-style control. Because of this, its appearance will not be platform-specific." What is the significance of this message and the pros and cons of not using controls from the system pallette.
Use the controls from the System palette when you want your UI to look like standard dialog UIs in your operating system. For analyzing any other kinds of VIs (test VIs, subVIs, instrument panel VIs, palette VIs, etc.), you should deselect this VI Analyzer test to reduce the amount of "noise" in your results.
