VI -VISA write was shown Error message .the NI Measurement&Automation Explorer shown abnormal information ,see the picture.
I have a device connected by TCP/IP , as shown in picture. but now the Measurement&Automation Explorer shown abnormal information , please see the picture.
the abnormal information is : Device Status: VISA returned this static device when finding resoureces,and MAX was able to use VISA to parse the name ,Max was not able to successfully open a VISA session to the device. )
How to solve this problem ??
It causes the TCP/IP VISA command to often fail to send to TCP/IP devices, but the network connection is normal ,and packets can be received normally when using the ping command. But use the VI program to send commands to TCP/IP devices. Often fail to send successfully, sometimes good and sometimes bad.
(1,612 Views)
Can I know your software (OS, LabVIEW and NI-VISA version) and hardware (Ethernet device) information?
Some quick search on the forum suggested that it could be a driver related issue.
https://forums.ni.com/t5/LabVIEW/Cannot-open-VISA-session-for-Hameg-HM8112-3/m-p/3053813
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-VISA-5-0-3-Driver-Wizard-PXI-Express-MAX-...
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(1,531 Views)
