12-05-2008 02:57 PM
Dumb question that is driving me crazy, but I gotta ask...
I have a VI. Its front panel has no scrollbars. I know that if the scrollbar were there, I could dbl-click and change the mode to Always On, Alwats Off, etc.
Since it is NOT there, now what? I can't seem to find it in the VI Server Props or methods anywhere either. I'm just stuck.
12-05-2008 03:07 PM
OK, Figured it out... but brace yourself...
You can only do it dynamically:
* Open a VI reference
* Get the Front Panel Reference
* Get the Array of Pane References
* Index the first element
* Set the properties for the Scrollbar visibilities from there
This is one of those cases where NI implemented what made sense to the programmigng paradigm (based on the addition of panes and scrollbar controls to LabVIEW) rather than considering the 95% likely use case (VIs with only one pane). This should be a VI Property.
Maybe it already is and someone at NI will show me what I am overlooking?
12-05-2008 04:35 PM
I found another way to do this in 8.5.1.
1. Create a verticle splitter bar on the front panel.
2. Right click the splitter and select a pane and activate the horizontal scroll bar.
3. Right click the splitter and select the other pane and activate the horizontal scroll bar.
4. Right click the splitter bar and select remove with adjoining splitters.
Hope this helps.
12-05-2008 05:47 PM - edited 12-05-2008 05:49 PM
10Things wrote:Maybe it already is and someone at NI will show me what I am overlooking?
Try VI properties...window appearance...customize... 😄
12-05-2008 10:03 PM - edited 12-05-2008 10:04 PM
I told you it was a dumb question... and that it should be a VI Property!
Thanks for the input.
