VI References to Running Clones
@ww.brown wrote:
I had a related problem with clones in 2012-13.  Attached is a solution sent by NI in 2013.  Hope this helps!  WB
It's in 2014...
Message 11 of 13
(708 Views)
The task manager I've seen does this very inefficiently (it could have been an older version). It calculates the clone crc every time it iterates over the possible clone names:
For each VI
 For x = 1 to n
  calculate crc
  ref = crc + x
The crc doesn't change, it's only input is the VI name...
For each VI
 calculate crc
 For x = 1 to n
  ref = crc + x
Just a hint. It will be hundreds of times faster.
Note that this is unsupported although it works. It might very well change in future versions of LV (NXG for sure).
Message 12 of 13
(708 Views)
Thanks ww.brown,
I went with the hash you posted.  I use the clone VI's Front Panel Window: Title property to uniquely configure and subsequently select the clone instance I want to automate.
Thanks to all who posted.
Steve K
Message 13 of 13
(676 Views)
