VI PROBLEM GALIL CONTROLLER
Anybody know why this VI does not do what it supposs to do when connectng to a DMC-4040 Galil controller? The VI connects perfectly to the Galil however when I input the angles it does not move nor does it activate the motors to move the aparatus. ?????
(4,121 Views)
Are you sure the commands are correct? Does the vendor provide examples you can use to verify your logic? This sounds like it might be a problem to be talking about with Galil.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,096 Views)
Hi, I do have the same issue.
How did you fix it? Do you have an example to share?
Thank you.
(3,518 Views)
hey - i know this is old, but hey seems Galil is still floating around. I got pulled into a project at work this week with one... Side note, I had to install there main SW to get LV to work with the ActiveX property nodes. GalilTools | Galil
attached is the VI. I don't have the same HW, so I could not test the buttons, but I suspect the event structure is not behaving the way you need. attached is an event structure with timeout active and the error case will stop the VI. (LV2020 SP1)
(1,244 Views)
