08-11-2011 03:52 AM
I am using LabView RT, where an application loads LLBs at runtime:
1- The user creates/compiles a LLB containg a VI that is loaded at runtime later
2- The user renames the contained VI to an enumerated name so that all names are always unique
3- The user uploads the LLB (containg the VIs with a unique name) to a LabView RT system
4- The LabView RT application openes all available VIs contained by the uploaded LLBs at runtime (the filename hints at the VI's unique name)
5- The LabView RT application executes the now opened VIs
My problem is step 2 where the user needs to rename the VI. This is because the RT application will not be able to distinguish between the opened VIs if their names are equal. I want to eliminate step 2 because it's error prone as the user always forgets to do the renaming or the user does the renaming in a wrong way (e. g. non-unique, typo).
A dirty hack would be to automatically replace all VI name strings (which are alidentical and like a placeholder) inside the LLB binary with unique ones at RT application's runtime. So the application takes over the renaming task.
Any other solution?
