02-03-2020 06:41 PM
02-03-2020 07:02 PM
Seems like simple homework problems.
I'm sure you learned enough in class to be able to finish it yourself.
Good luck and earn that "A"!
02-04-2020 12:18 AM
@sguy12 wrote:Which solution is easier to program? Which solution provides a quicker way to change formula?
Hmm... guess it depends if I can guess right with the formula node or need to open the detailed help to get the right syntax...
I'd be tempted to disagree with what I expect is the desired answer based on the nice quick-drop plugins...
02-04-2020 07:34 AM
@sguy12 wrote: For the second solution use the Formula Express VI.
I would rather use the Formula Node. I often find it easier to read and edit when dealing with some complex math.
02-04-2020 08:16 AM
I don't use the formula node because I really suck at typing. A mouse-driven programming language was a gift from [insert the mailing address of your favorite deity/deities here].
02-04-2020 08:28 AM
I typically don't use the Formula Node because I don't normally have to deal with weird/complex math. But occasionally (once every few years), I do and it is nice to have the Formula Node around for those situations.
02-04-2020 09:04 AM
At my previous company, I had to re-invent the wheel because they only had LV basic 😞
Implementing a linear regression line fit in native LabVIEW functions started to get ugly...
Formula node could of made it a bit nicer... but that is cheating. LOL
02-04-2020 10:02 AM
You could have made it a lot cleaner by implementing a Square function and used the compound node for the three factor multiplication (or made a sub-vi of it, or just change the order of the wires since multiplication is commutative.
/Y
02-04-2020 01:14 PM
The simplest solution is to use physical quantities. You won't need to use any functions at all.
02-04-2020 03:26 PM
I always love how someone who creates a post trying to trick people into doing their homework for them, never responds back, but there is a long thread among the regular forum users anyway.
