I'd like to use the non DAQmxBase VIs used in this attached VI in my C code (under GNU/Linux).
I found all the necessary functions about the DAQmx VIs with the
drivers of this latter, but the signal processing VIs in the "Detect
and count impulses" while loop are not part of it...
There are no analysis functions included in the device driver libraries. Those are part of the development system- in your case LabVIEW. CVI, Measurement Studio, etc., all come with their own. You can see what kind of analysis routines are available for GNU/Linux or, if you have LabVIEW for Linux and the application builder for Linux, create a shared library from the VIs and call that in your C code.
