02-15-2006 12:33 PM
02-16-2006 07:00 PM
The Remote System tab is for RealTime targets, such as FieldPoint, or LabVIEW RealTime. I understand that you want Computer A to have all the DAQ hardware, but run no code, and have Computer B run the LabVIEW code but talk to the hardware on Computer A. This is not possible, and not what the Remote Systems is for. Now what you can do is take advantage of the new Shared Variable in LabVIEW 8.0 to share data from A to B. A hypothetical setup would be to have Computer A have all the DAQ hardware and be running the DAQ program to acquire data, but then share the data to Computer B via the shared variable, i.e. use that as a transport method. Let me know what your application is, and why you want to separate the program from the DAQ setup. The shared variable would be a good way to go, but depending on what you are trying to accomplish I might have some other suggestions. Hope I can help.
-GDE
02-21-2006 12:21 PM
Thank you for your reply GDE [DE]!
That’s too bad. I assumed too much and thought we
were able to do something fancy.
I work at a test facility where the tests that we run are hazardous.
We have a lot of concrete walls between us and the tests that are run. We
have a test console setup where we have our entire test monitoring tools in a
central location. The problem is, whenever we make a new test chamber all
the transducer lines have to be drawn to our test console. These lines
consist of analog outputs from Omega DP units that power and read pressure
transducers and K-type thermocouple channels.
This makes it difficult, if not impossible when time is
constraining, to setup for a new test. Some of our newer test chambers
and rooms that we have added to our facility are further and further away from
our test console. Long analog lines are not good for noise reasons.
Long thermocouple channels are even worse since the signal is so small and varying
temperature gradients across the line can affect measurement readings.
The solution that seems apparent to me is: why don't we
read our transducer values closest to the test cells and network that
information back to the test console through a high speed gigabit network?
I was hoping that a remote data acquisition computer would
just consist of an operating system, the hardware and hardware drivers for DAQ,
and then MAX. The computers at the test console would be in charge of
actually administrating the test procedures (Digital I/O) and DAQ through the
network.
I have looked at the web features available in our license
of LabVIEW 8 Professional Developer and I'm pretty impressed with its
capabilities. The problem is I don't want to have to obtain a LabVIEW 8
license for each remote computer. It is just too expensive. I can
build executables with my developer’s license of LabVIEW 8, but I don't think
that the web server features can be built into an executable LabVIEW program
(or can they?).
Can I use this shared variables solution that you speak of
in a LabVIEW built executable?
I hope that I have provided enough information about my
problem to help stimulate some possible solutions and more discussion. I
really appreciate the help that these forums provide and hope that I am able to
give back to this community.
-Nic
02-22-2006 01:25 PM
02-22-2006 01:47 PM
02-22-2006 01:48 PM
02-22-2006 02:02 PM
02-22-2006 04:50 PM
