09-04-2012 01:14 PM
I can't seem to show symbols in the second column of a multicolumn listbox. I tried some example code I found on NI.com and there seems to be something unique about the multicolumn list box they used in the example. If I put down a new one it doesn't work. What's the trick?
09-04-2012 01:16 PM
Can you show us what is the code you are using and also your work? (2009 version please)
09-04-2012 01:21 PM
Did the example use Row Headers? That's the only thing that makes sense to me.
09-04-2012 01:22 PM
09-04-2012 01:32 PM
Here are my findings from my quick playing around.
09-04-2012 01:36 PM
The following statement was copied from the LabVIEW Help topic "Adding Symbols to Listboxes and Tree Controls":
Note In a multicolumn listbox, LabVIEW adds the symbol to the first column.
In my own experimentation, I havent found a way to add symbols to the other columns. Is it possible that the examples you've found are really just adding symbols into the text itself? I agree with the previous post, we'll need to see the code you're working with.
Matt Kirk
Inventor of ImageJVI
09-04-2012 01:39 PM
I am assuming you are referring to this example: Inserting Images in a Multicolumn Listbox in LabVIEW 8.x. For a multicolumn listbox, that only works for the first column. If you want symbols on other columns, then one way to do this is to set that column to a font that uses symbols, like the example for showing folders that I showed.
09-04-2012 01:46 PM
Nope, I am using this example.
https://decibel.ni.com/content/docs/DOC-14549
I edited this code and added symbols to a third column and it only shows up in the control 'MC Listbox'.
09-04-2012 02:16 PM
That example appears to use a custom control, rather than a standard multicolumn listbox. Without investigating it, I'm not sure how it was done.
09-05-2012 08:17 AM
Hi Doug,
Can you clarify what you are trying to do? You mentioned that you modified the example. What modifications were made? Can you please attach your code?
