Using negative X and Y scale in a intensity plot
Highlighted
I try to plot a measured intensity (Z) over the coordinates relative to a transmitter (X and Y scale).
The X and Y scale range from -5 to 5 and I feed a 11x11 array into the intensity graph. I then scale the plot using a property node XYZ-scale min/max/increment to scale my data, but this only scales what is shown in the graph. Is there a way to tell the intensity graph to actually show data for negative values?
Thanks for your kind help!
(258 Views)
Highlighted
Accepted by topic author jschfr
I don't know the answer to the question about intensity graphs showing negative values.
I am guessing it can't because if Black =0 then values <0 would be blacker than black.
How about scaling your graph data so it's always positive?
I suggest looking into the offset and multiplier properties of the graph.
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
(235 Views)
Highlighted
Thanks a lot!
Offset and multiplier it is! That way the XY values can be shiftet into negative range.
Z scal was alreadyset to autoscale, so negative Z values would have extended the range.
(228 Views)
