Using jQuery UI in LabVIEW NXG
Highlighted
jQuery UI is a curated set of user interface interactions, effects, widgets, and themes built on top of the jQuery JavaScript Library. Whether you're building highly interactive web applications or you just need to add a date picker to a form control, jQuery UI is the perfect choice.
https://jqueryui.com/
Attached is an example of using one of the controls in jQuery UI, the DatePicker. Feel free to use.
Front PanelFront Panel
Block DiagramBlock Diagram
Message 1 of 1
(174 Views)
