03-20-2008 08:19 AM
04-02-2008 07:32 AM
Hi Danny,
I've been trying to get my head round your forum post, so I want to check if my
understanding is completely correct. U have several (how many?) PXI chassis and
want to synchronise the 6221 DAQ cards within each chassis and you wish to
syncrhonise these within 1Hz of each other by using a 10MHz GPS signal.
Currently you are getting this signal in by the controller reference point yes?
I think the easiest method for you to get this up and running is to wire in the
10Mhz signal in a slightly different way. The easiest would be to override the
backplane clock source with your 10MHz signal. to do this, wire in your gps
signal to the BNC connector on the back of each chassis. this will then override
the backplane source, and them simply use this clock reference in your program.
If your chassis does not have this connector on the back (some of the lower end
models do no), we can try using a PFI line on the actual card itself. this
would make synchronisation alot easier than using the controller trigger input
which is not very suitable for this kind of application.
Let me know how you get on
Best wishes.
04-02-2008 07:41 AM
