02-06-2007 02:07 AM
02-06-2007 08:44 AM
Hello Pandiarajan,
Since I didn't see it mentioned, I'm going to presume (hope) you're using 8.0. In LabVIEW 8.0, certain parts of XControls ran in a different application instance than where the VI was. This was a source of many issues related to XControls. In your case, since Express VI configuration pages also run in a separate application instance (and a different one than the XControls), I suspect this is related to the problems you are seeing. If this is the case, it may not be possible to use an XControl on the front panel of an Express VI config page in 8.0.
The resolution to many of these issues was to allow these XControl parts to run in the application instance of the VI whose front panel contains the XControl. This fairly substantial change did not make it in until LabVIEW 8.2.
If you are already using LabVIEW 8.2, it may not be an easy issue to troubleshoot, but I'd like to help isolate this issue. If you can simplify your XControl / Express VI into something that you could package and attach to this thread, I'd be willing to take a look at it.
