06-17-2015 08:59 AM
Hi All,
We used report generation tool kit to generate the report on word and with other API 's under it,we get good reports .
But when the data points are more (> 100 on all channels) it take a long time to write all data and create a table in the word and generate report.
Any sugegstions how to make this happen in some seconds .
Please assist.
06-17-2015 09:13 AM
You say > 100 data points on all channels. How many channels? Can you post an example of your data?
06-17-2015 09:25 AM
I simulated some text data with 8 columns and 63 rows and it took 15 seconds to write it to a table in Word. Another reason why Word sucks.
06-17-2015 09:35 AM
total channels will be 24,but often 16 channels will be used .
idea is to read available channels data from XY graph (data type =Single ch.will be a cluster of X-time stamp and Y-will be data points) and generate report
100 is an examples here ,more than that we will use to generate report
06-17-2015 09:43 AM
Can you generate the report in a separate loop as the data is being generated rather than pulling it out of a graph point by point at the end of the process?
06-17-2015 10:54 PM
I've used the Report Generation Toolkit quite a bit to read/write Excel Workbooks and to create HTML reports. I never tried to create a Table (a "natural" thing for Excel to handle) in Word with LabVIEW. I agree with aputman that it is quite unsatisfactory.
This may be a silly question, but why not use Excel for the table? You should be able to create a 24-channel, 100-row "report" in Excel in a second or so (maybe less). And it will "look pretty". And, if you really do need to generate a Word report, write the table into Excel, then use Word Insert Object, whose help says "If the object is a Microsoft Office object such as an Excel worksheet or a PowerPoint presentation, the Word Insert Object VI embeds the object into the document." [I'm assuming that Insert Object is faster than inserting all of those Table elements one at a time ...].
06-18-2015 08:13 AM
06-18-2015 07:30 PM
Well, I just tried my suggestion. I simulated a 24-channel data producer (I actually generated 25 numbers -- the first number was the row number, followed by 24 random numbers) and generated 100 of these for a total of 2500 double-precision values. I then saved this table to Excel and closed the file. I then opened Word (all using RGT), wrote a single text line "Text with Excel", inserted the previously-created "Excel Object", and saved and closed Word.
First, it worked (sort of). The Table in Word started on a new page, and was in a very tiny font (possibly trying to fit 25 columns on a page? I didn't inspect it very carefully). This is probably "too much data" to really try to write the whole table, unless you format it for, say, 3 significant figures.
Now, timing. I ran this four times, two duplicate sets, one with Excel and Word in "normal" mode, one in "minimized". To my surprise, this didn't make a lot of difference (minimized was less than 10% faster). Here are the approximate times:
Generate the data -- about 1 millisecond.
Write the Excel Report -- about 1.5 seconds
Write the Word Report -- about 10.5 seconds
Seems to me this is way faster than trying to do this directly in Word.
06-18-2015 07:41 PM
P.S. -- I realized I could add a "Pure Word" test to my existing code -- simply open Word again, save the 2500 numbers using Word Easy Table, and save with a different name. Not sure of the timing -- Word crashed after about 30-40 seconds. Running minimized didn't help. Here is the error message:
Exception occured in Microsoft Word: Value out of rangeHelp Path is wdmain11.chm and context 37376 in NI_ReportGenerationToolkit.lvlib:Word_Insert_Table.vi->NI_Word.lvclass:Append Numeric Table to Report.vi->NI_report.lvclass:Append Numeric Table to Report (wrap).vi->NI_ReportGenerationToolkit.lvlib:Word Easy Table (num).vi->Excel and Word Test.vi
BS
06-22-2015 08:26 AM
Word probably crashed because the table was too wide. I experience the same thing when I tried generating data and populating a table directly to Word. When i delete columns, so that they all fit on one page, it didn't crash.
