The basic way of converting to VISA serial io is to write versions of the existing low-level serial VIs that logicallly perform the same operations, but using VISA calls. My sense though is that this change won't inherently help the situation. It sounds like a command is timing out and that timeout condition is not being trapped correctly (if at all).
A lot of old VIs--even (especially?) NIs--contained little or no error handling. In fact it was very common for them to be written with the assumption that nothing will ever go wrong so there is no error reporting at all.
Are Horba's drivers available somewhere online? If so I'll grab a copy of them and look for logical holes in them for you.
The other half of this equation though is the logical operation
of the Horba equipment. If a communication timesout how does their control software respond? Is there any sort of special recovery operation that you have to go through? For example, getting the sort of indication you are from a spectrometer makes me wonder if the instrument is getting hung-up internally. (I'm assuming here that this spectrometer is an electromechanical device like some of the fiber-optic instrumentaion I have used in the past).
Is this instrument provide a GPIB interface? If so you might want to consider that interface for talking to the box as it can at times be more reliable and faster.
This could be a mess to troubleshoot but I'll do what I can to get things cranking for you.
Mike..
