Using Text File Data to Plot out a histogram
Hi professionals of NI,
I have a text file data attached with 3 columns of data and I would like to plot it out with a histogram.
Unfortunately, the create histogram data doesn't let me extract out the values I would like to plot it out...
I have viewed from some of the older threads on how to do it, sadly it was a very long thread and the Vis, images were corrupted.
Does anyone have a great solutions for this....? Really appreciate it!
(1,851 Views)
Hi Lexen,
Do you mind to explain HOW you want those data to be plotted?
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(1,831 Views)
Hi there Dark Knight,
Thanks for the response. As shown from the graph I have to make out something like this.
As for "plot it out" meaning I think it would be when I load the test file into the file path, the list of 3 columns would show out in the graph say C will the red color, G will be blue and D in green....
(1,827 Views)
Accepted by LexenZ
Hi Lexen,
no need to use ExpressVIs:
I used the simple Histogram function, there is an advanced one where you can provide more parameters. And I used LV2011, so the ReadSpreadsheetFile function looks different to the one in recent LabVIEW versions.
I don't know what CGD means, but changing plot properties should be easy enough!
(1,822 Views)
Dear Dark Knight,
Omg your such a godsend, I have managed to work it out and did it as shown!
Thank you so much!
I have another issue I am not sure if I should post it here or create another post again?
(1,817 Views)
