Using Notifiers with Case Statements
hi,
I have two while loops. The top while loop using an event structure will run when a button is pressed. This will send a notifier to the 2nd while loop which holds a case statement(state machine) to run multiple states. I am seting up the 2nd loop with the case statement using a shift register to allow running whatever state needs to run. I wanted to pass an Enum constant from the Top loop to the 2nd loop and have the Case statement run that case to start the process. I dont see how to have the case structure see the notification or how to break into the shift register that feeds the case structue of the 2nd loop. I dont really have code to post on this. I have been looking at examples but have not found anything like this.
thanks
(1,012 Views)
This is sounding a lot like the Queued Message Handler.  You might want to look into that example.
GCentral
(998 Views)
To have thought it out on your own is pretty cool, though.
Bill
CLD
(Mid-Level minion.)
(976 Views)
