Hello Sarah,
Thank you very much for the link. I tried to run the vi "Meas Buffered Pulse-Period(DAQ-STC) which is the vi under the topic "Measuring Various Types of Pulse Periods". However it does not give me reliable results. I run the VI first and it loops for the measuremnt to happen. Then I apply the gate input, and the VI finishes and gives the readings.
The following is the configuration I used.
Device: 1
Counter: 0
Time base: 20MHz
Config mode: measure buffered semi-periods
gate source: gate of the counter
gate signal: x(don't care)
gate mode: rising edge
I am not too sure what the "counts per buffer" is. Is it the number of periods to measure and write into the buffer. I set this to 1 first, since the input that I am applying at the
gate of the counter is only one positive pulse of about 350 ms. This did not give me any consistent value, sometimes the count reads 1 or 2 and sometimes very high number. If I set the counts per buffer to say 3, it still reads 3 values into the buffer, which I think is not correct, as the gate gets only 1 positive pulse.
I also tried another input at the gate this time 2 positive pulses(each of ~350ms) with a gap in between of ~450ms. I set the counts per buffer to 3 as there are 3 periods to read. Again the readings don't make sense. It appears that it is just taking 3 reading without waiting for changes in the gate input.
Is it possible that the gate input is affected by nosie and gets triggered at unwanted points and causing the measuremnets to be taken without waiting for the actual pulse to complete. How can this be prevented. How sensitive are the gate inputs to noise?
Hope you have some suggestions.
Rgds
Eapen
