07-01-2011 01:55 PM
Since the dimensions are being transmitted in your header, it seems like you would be able to assemble a 2D array by "breaking" your 1D array into rows as defined by the width property in the header. For example, if your image is 320x240, you would make a new row after every 320 elements in your 1D array.
07-06-2011 03:46 AM
Thanks friends, it finally worked with this solution:
http://forums.ni.com/t5/LabVIEW/How-can-I-decode-a-data-stream-to-jpeg-image/m-p/1619856#M585864
10-04-2021 11:59 PM
Hi londonew
can you please post the full VI after you modified it and after you added the solution?
