Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
User32.dll Causing Error on Application Exit
Yes that clears up what you last said. Also I'd like to add that it works the same if you just put the name of the dll in the dialog box without the full path as someone suggested above. It won't be copied to the application directory this way either.
Thanks for your help.
Message 11 of 11
(576 Views)
