04-05-2011 12:57 PM
Why does this code give an error. I copied it directly from the example. My first thought was that I had to create the process first. This was not the case. It could be the user input. If it is, how do I know what the username is?
Matt
Solved! Go to Solution.
04-06-2011 03:38 PM
Hello Matt,
The problem is not clear to me, what error are you seeing?
Eric L
04-07-2011 12:25 PM
The problem seemed to be that when you run it the first time the VI generates a user defined alarm and when you run it here after, an error is generated because the first alarm hasn't been acknowledged.
