10-12-2011 03:52 PM - edited 10-12-2011 03:58 PM
I try to cut a waveform when the curve value is greater than a threshold value.
I use a switch and I generate the cut signal 0 (FALSE) for return 0 and 1 (TRUE) to return the value of the waveform.
But I have a null waveform as result !!
Do you have an idea because when I use a switch on the front panel, the result is well but manual !
See attach files.
Solved! Go to Solution.
10-12-2011 03:59 PM - edited 10-12-2011 03:59 PM
I am not sure if I understand you problem correct. But see if this VI helps
Y[i]=Clip{X[i]} VI
Owning Palette: Signal Operation VIs
Installed With: Full Development System
Clips the elements of Input Array to within the bounds specified by upper limit and lower limit.
10-12-2011 04:20 PM
I have modified Vi with clip and It's work fine.
Thank you very much.
