Use boolean valaue change to trigger valaue change in Event structure
Hi.
I am trying to build an alarm system for triggering an alarm whenever a given valaue is reached.
Is there any way to get a action which triggers a valaue change in a event structure whitout having to use a button?
I.e: If the simulated valaue reaches 45 i want a H alarm to go off, if it rises to 50 i want a HH alarm to go of, etc.
See attached VI.
Message 1 of 11
(5,592 Views)
I do not have base development system...
Message 3 of 11
(5,588 Views)
Is there any way to do this iwthout Creating custom events?
Message 4 of 11
(5,570 Views)
Using the property Value (Signaling): http://digital.ni.com/public.nsf/allkb/024828947672E68586256ADB0071FB1B
uday
Message 5 of 11
(5,567 Views)
I have already tried this, and though it was the apparent solution. But it keeps on writing an alarm for every iteration of the event structure, instead of just writing when it enters the given limits.
Do i need som sort of reset function?
Message 6 of 11
(5,561 Views)
How have you implemented the use of the Val (signalling) property?  An event will fire every time the property is set whether it has changed or not.  Post the vi with your latest attempt.
Ken
Message 7 of 11
(5,553 Views)
Even if the valaue is inside the given valaue the H boolean writes an alarm for every loop iteration.
Ask if there is any questions to the VI
Message 8 of 11
(5,541 Views)
Thats because you execute Val(sgnl) every loop.  If you only want your Event to trigger when H is TRUE then you have to only call Val(sgnl) when H is TRUE.
To reiterate, Val(sgnl) ALWAYS fires the event regardless of whether the value is a change from the last value.
The false cases are empty
Ken
Message 9 of 11
(5,525 Views)
Accepted by Magnhel90
Also note that you will keep getting the alarm event each iteration as long as this is TRUE.  If you just want a single event when the alarm condition goes TRUE, you will want to add a Boolean Crossing PtByPt to detect the transition from FALSE to TRUE and use that for the case structure.
Message 10 of 11
(5,507 Views)
