05-06-2021
06:32 AM
- last edited on
06-03-2021
04:45 PM
by
NI_Community_Su
Dear all,
05-06-2021 11:39 AM - edited 05-06-2021 11:39 AM
Hi ibtihel,
I found a user manual online for the E5080, not sure if it pertains to the N5224 model as well.
http://ena.support.keysight.com/e5080a/manuals/webhelp/eng/
This function is going let you save the SNP data to the analyzer, then you probably have to figure out how to transfer the file to your PC afterward.
05-06-2021 03:11 PM
hi gregory,
i want to know if i can automate the VNA and even save the data in a file with my labview vi . i mean configure the frequency power and number of measurement points then it saves the real/imaginary s-parameter in a file . automatically and not manual . im going to communicate with GPIB .
is it possible?
05-06-2021 03:30 PM - edited 05-06-2021 03:30 PM
Yes, if you can find it in that manual I linked to you can send it to the instrument. For example, to set the number of points I would try this command:
05-06-2021 03:38 PM
05-14-2021 02:09 AM
Hi !
Can you please take a quick look at my PNA VI , I feel like everything is ok, when i make the highlight execution it stops at the for boucle of the sweep complete after sending a trigger , can you please take a quick look and let me know where is the problem doest it query a data or not.
07-26-2022 05:18 PM - edited 07-26-2022 05:20 PM
Hello
Hope you are well
I am m going through the same issue saving s2p files from N5224A.
Although you can download Keysight PNA drivers but need to create your code to save data in SNP format. I got an overview from this code which is available on NI community where in I further made changes accordingly for my instruments N5224A.
I hope this code helps you.
Kind Regards,
Gauri
