Upgrade LV2009 to LV2010 issue with ActiveX dll
Good morning
I just try to update a LV software made with 2009 to 2010 (same PC). I try to open a reference from a homemade ActiveX. In 2009, everything is fine. In 2010, I got this error
21343i3CBB27D831312AD1
But, if I save the VI for LV2009, open/run in 2009, it's working fine. If I try common ActiveX (from external software), everything is fine.
21351i11E891C797B6646D Don't work
21353i15C5DC535F12676AWork
Any idea?
Message 1 of 11
(5,239 Views)
Can you post your dll here for me to reproduce this?
-Zach
Message 2 of 11
(5,203 Views)
This is a Matlab dll, so if you want to use the dll, you will need Matlab runtime install on your PC. Matlab Runtime MCR7.10 (if you don't have, I can send you the runtime, but 152Meg...)
Thank
Message 3 of 11
(5,190 Views)
I do not have their RunTime. Do you have a download link that you can post? If not, you can place it on our FTP site at ftp://ftp.ni.com/incoming.
-Zach
Message 4 of 11
(5,168 Views)
I'm uploading the MatLab Installer (MCRInstaller.exe) on you ftp site. Hope you can help me with this issues because this is a show stopper for move to LV2010
Thank
-Zach
Message 5 of 11
(5,163 Views)
Accepted by CFiset
I reproduced this issue and submitted it for further investigation under CAR #245249. I apologize for the inconvenience.
-Zach
Message 6 of 11
(5,139 Views)
Since this is a major bug for us, we can't use LV2010 until this is fix.
Thank
Message 7 of 11
(5,135 Views)
I would like to get some additional information from you:
1) Do you have multiple versions of LabVIEW installed on this computer?
2) Exactly what Operating System are you running?
-Zach
Message 8 of 11
(5,119 Views)
-Zach
1 - Yes, I have LV2009 and LV2010 install on my PC (Full Developpement System - 32bits)
2 - I'm runnning under WinXP SP3 32bitsIf any else that I can help you with, let me know
Thank
Constant
Message 9 of 11
(5,078 Views)
So here's what I've found out:
1) Having multiple versions of the same dll on a computer can cause the Not Able to Locate an Entry Point issue
2) The RTE you provided installs tbb.dll here: C:\Program Files\MATLAB\MATLAB Compiler Runtime\v710\bin\win32\
3) tbb.dll is also installed in C:\Windows\System32
4) The versions between these two locations are different and looks to be what is causing the problem
The preilimnary workaround is to rename the tbb.dll in System32 to tbb.dll.backup so that it doesn't get lost and then copy the version from your RTE into the System32 folder. This should get LV 2010 working although there are some caveats. If you do this, you will not be able to use Vision Builder AI and most likely the Vision RTE because they have similar dependencies. If you do not have either of those packages, I would not worry about those. The other thing is that the dll will no longer work properly with LV 2009. We know this is not ideal and are looking at other ways around this.
-Zach
Message 10 of 11
(5,060 Views)
