Update waveform segments via Omega Personal Daq 3000
Hello to everyone, 🙂
I am having some issues with updationg waveform segments via my omega personal daq 3000.
The goal is it to generate a 1 Hz square waveform, which updates every cycle.
As I wanted to avoid generating a new waveform every cycle, I tried updating it.
In the example, which is given by omega, a waveform made up of 5 segments is generated, and then the third (index 2) segment is updated.
I have tried rebuilding it in a way that only one segment is generated and then updated, but I failed miserably.
Configuring the example VI in that way failed too.
Actually I am not even able to set the example VI  to update other segements than the third one.
I assume that "wavelet index" is the right point to set it, but if I set it to sth. other than 2 it just does not update anyting.
I can change the five segments of the waveform, and the update too, but I am not able to set the update to anything but the second segement.
I hope that it is just a simple setting to change, but I just can't find it..
Does anybody have an idea what I could try?
Thank you very much in advance,
Keksbold
P.S.: I have attached a file so you can see what the problem is:
5 segments: sine, square, triangle, sawtooth and noise, and for any reason I am not able to update any but the third segment..
(2,588 Views)
Accepted by topic author Keksbold
Problem solved!
I do not know why, but removing the DAQIO wave status sub VI fixed it.
I would be really interested in finding out why the VI behaves like this anyway, so if anybody has an idea..
(But is not vital anymore 🙂 )
Thanks to everyone!
Keksbold
(2,531 Views)
