01-19-2012 03:32 PM
Very new to LabView.....but definitely interested in learning.
Anyone have experience converting VIs from V7 to 2011?
I know there is the upconvert board but our program is quite large and has many VIs and we'd like try and convert it ourselves.
Just wondering if this is a wise idea or we're setting ourselves up for a whole lot of trouble.
Thanks!
01-19-2012 04:11 PM
01-20-2012 07:02 AM - edited 01-20-2012 07:03 AM
Is there conversion software I should be looking into?
Thanks!
01-20-2012 07:36 AM
Are you referring to DAQ? Or are you referring to conversion of the code? If you're referring to DAQ, and you used Traditional DAQ and need to convert to DAQmx, there is no conversion software - you have to replace the code manually. There are several articles in the NI KnowledgeBase that can help. Here's two:
01-20-2012 07:38 AM - edited 01-20-2012 07:40 AM
No, sorry, I should have explained a little better.
I'm refering to conversion of the code (VI's etc)?
Thanks for your time
01-20-2012 07:56 AM
LabVIEW 2011 can open LabVIEW 7 VIs directly. Once opened they are automatically recompiled and will require saving. Some functions/VIs will obviously have changed so you may have to fix some code, but it's impossible for anybody to tell you what will be broken since it depends on what you used and how.
01-20-2012 07:58 AM
Great! Thanks, I'm just installing 2011 right now, so once it's done I'll give it a shot.
The last person that worked on this mentioned they had trouble with video drivers afterwards....we'll see!
Thanks everyone for your help and clarification.
Cheers
