12-07-2007 03:15 AM
Second try (stripped down code):
Deploying ZLIB Close Zip Archive__ogtk.vi
Failed to download ZLIB Close Zip Archive__ogtk.vi
LabVIEW: Failed to load shared library lvzlib.out:zipClose:E on RT target device.
12-07-2007 03:22 AM - edited 12-07-2007 03:29 AM
Mads wrote:
I took a copy of a OpenG lvzip VI and modified it to use the new dll. Downloading the code to the RT target fails.First try:Deploying Error Code Database.vi (3,67 K)
Deploying ZLIB CRC32__ogtk.vi
Failed to download ZLIB CRC32__ogtk.vi
LabVIEW: Failed to load shared library lvzlib.out:crc32:E on RT target device.Second try (stripped down code):
12-07-2007 03:28 AM
Ok, was not aware of that issue. I have an old cFP module I could try it on instead though...I'll see what I can do.
Thanks for the effort by the way, it is really great of you to go this length to help.
12-12-2007 08:54 AM - edited 12-12-2007 08:55 AM
12-12-2007 09:52 AM - edited 12-12-2007 09:53 AM
rolfk wrote:
Can't test them myself currently but let me know what you find out.Rolf Kalbermatter
12-20-2007 04:56 PM
Finally got around to taking a look at this. The OpenG Zip VIs actually work fine on my Phar Lap RT target with the same old OpenG LVZLIB DLL! Did I miss something?
12-20-2007 05:20 PM - edited 12-20-2007 05:22 PM
12-21-2007 02:59 AM
12-09-2008 04:28 PM
Hi Rolf,
I was wondering if you had tested the new lvzlib.out file. For some reason when I run the a ZIP VI it causes the controller to hang. In particular at a Call Library Reference Node. Thanks.
12-10-2008 12:49 AM - edited 12-10-2008 12:55 AM
