Unsuccesful build installer: Upgraded product
I've been searching the forum for a solution for this.
I can't build an installer for our software since it keeps failing on an upgraded product. I get the following error:
The following product(s) are not found on the system or have been upgraded:
NI-DAQmx Application Development Support 18.5
Error 7 occurred at CDK_Utility_GenerateErrorCluster.vi -> CDK_Validate_DistParts_2010.vi
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface.
I tried updating the NI-DAQmx and Labview drivers. Got a "can't install version 18.5 since a newer version is already installed" once, but I think that's the problem? Why doesn't labview automatically update the version used in the builder? How can I manually do so?
(2,449 Views)
Accepted by topic author DennisvdH
Hi Dennis,
In the Installer Properties dialog - check the "Additional Installers" page.
If it is not set to "Automatically select recommended installers", it may try to use a previously selected version.
The DAQmx version detected by the installer should match what shows up in MAX (My System -> Software).
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
(2,416 Views)
Right, that got my through the process of building the installer. Now waiting on our IT department to test it on a clean device (that's where we had issues with certain drivers not being included in the installer). I'll update as soon as I've had a response.
(2,385 Views)
