Unregister dynamic events
Hallo,
is there a way to unregister a certain event from an event loop?
Liebe Grüße
Oliver
Meine EMail enthält weder x noch q
(3,369 Views)
I don't see a very easy way to do this. But how about using a shift register in the outer while loop? Then you can delete all events you defined for this event structure and redefine all the ones you still want to use...
I never tried this, though.
Cheers,
    Carsten
(3,365 Views)
well, but how I can delete every generated event ?
thank you Smiley Tongue
(3,295 Views)
You can only unregister events dynamically that were created dynamically. So instead of statically creating your event for a front panel control, wire its reference into a Register Events VI and select the event you wish. Then you can dynamically unregister and reregister the event as needed. See here for more information, though keep in mind you'll be using control references most likely instead of user events.
Actually, this is a much better link to look at.
Message Edited by Jarrod S. on 08-16-2006 08:30 AM
Message Edited by Jarrod S. on 08-16-2006 08:32 AM
Jarrod S.
(3,281 Views)
