Unexpected behaviour of functional global with notifiers
Hi all,
I created a functional global to manage a list of notifiers (see attachment). It returns a notifier reference according to the element name specified as input.
If a new element name is specified, a new unnamed notifer is created (Obtain notifer). If an existing element name is specified, the notifier reference (previouslty initialized) is returned.
This structure is used to manage notifier for classes. Different classes use different notifiers.
The first time I call the FG, the notifier is initalized and a valid refnum is returned. The second time I call it, Invalid Refnum is returned.
Why this?
Message 1 of 9
(4,514 Views)
It may be because you have no Initialise case.  The arrays may not be empty when you start, and so the names and values may not match, or the references may be invalid. IN your initialise case, empty the arrays.  It is also worth mentioning that this is a prefect use case of a Variant Lookup Table, which will perform faster and with less coding than the search 1d array method you are using.  There are many examples of variant lookup tables on these forums.
Message 2 of 9
(4,498 Views)
I've added the initalization case that empty arrays but this strange behaviour remains,
I'm looking at Variant Lookup Table now. I didn't know it. Thanks for your suggestion.
Message 3 of 9
(4,481 Views)
Accepted by sqrt(-1)
Between the first and second call, does your VI go idle?
If so, the notifiers are being destroyed when LV clean runs.
Ben
PS: I like the Variant lookup as well.
Message 4 of 9
(4,475 Views)
please make a simple test VI which gives you the strange behaviour.  I tried your VI and it works as far as i can see
Message 5 of 9
(4,473 Views)
@sqrt(-1) wrote:
Hi all,
Why this?
You should wire the new element name to the Obtain Notifier name input in the not found case.
notifier FG.pngBen64
Message 6 of 9
(4,469 Views)
@ben64 wrote:
@sqrt(-1) wrote:
Hi all,
Why this?
Exactly! Name them notifiers.
Of course, then you can really go back and DELETE the element name list Smiley Surprised and throw the whole vi out the window as well
Spoiler
Just use obtain notifier-  All the FGV functions, including the variant lookup method suggested, are done under the hood-  LabVIEW is just like that sometimes, Smarter than we are
"Should be" isn't "Is" -Jay
Message 7 of 9
(4,461 Views)
Er- yes. of course.  Its a shame the same is not true of Events, DVR's... any more?
Message 8 of 9
(4,456 Views)
In all fairness, There are reasons to do exactly what was suggested.  To Wit: there is no method to return the names of all notifiers in this application instance.  This could aid a developer trying to figure out just where they typoed a name and got a new notifier rather than a reference to the notifier they wanted.
Attached in 2017
I just recently modified an lvlib that can be found in some shipping template projects to add a feature like this for Queues. (And disconnect a cluster typedef that I didn't like)
The example is missing dependencies.  (I have to hold something back in my pocket)
What a way to find my bugSmiley Embarassed Right there for everyone to see.
Message 9 of 9
(4,435 Views)
