08-06-2019 09:33 AM
I am not able to use my data acquisition card USB-4432 along with the DAQExpress software.Is it so that the DAQExpress will support only the cards which can be mounted on a cDAQ chassis?
Please help me in resolving this problem
08-06-2019 09:58 AM
I am noticing that the USB-4432 is listed as "Mature", which means it is on its way onto obsolescence. So it is likely it was given any support in DAQExpress. I do know DAQExpress works just fine with my USB-6212, so it is not just dependent on cDAQ. You might want to give your local NI sales rep a call and see if they can help you find something else that will work for you.
