When attempting to run the example program, I get the following error.
Error -1074126845 occurred at niDMM Fetch Multi Point.vi
Possible reason(s)
Max time exceeded before operation completed.
I have attached a screen capture of the front panel showing the setup.
I have a 4071 DMM in slot 12 and a 2527 Mux in slot 17 of my PXI 1045 chassis.
I can use the switch and DMM front panels to read the expected voltages on each of the 4 channels.
In my application, I will need to continuously capture voltages from 10 channels. I will display these voltages in floating point indicators and process numerous inputs from the front panel.
How do I get this example program running? Is this example a good implementation of what I need to do?
- les
