07-22-2011 06:39 AM
Hello all!
Sometimes we must upgrade some of our customer machines. Those machines where developed in Labview, but they only have the executable and the run-time.
Several times I have the a problem, we upgrade the Labview version on our PC's and we can not send them only the executable. We must make a new installer with the new version and install all that.
There is the possibility to create an EXE to a previous Labview run-time version?
Thanks in advance, best regards,
Paulo Carmo
08-01-2011 02:28 AM
Hi Paulo,
Thank you for posting.
You are only able to create .EXE for and with the version of LabVIEW you build it. You can choose the version of run-time.
For example, if you have LV 2010 and you want to deploy your application on Windows 2000 (not compatible with LV run-time 2010), you have to create your EXE with at least LV 2009 SP1, and the run-time version will be the same as LV.
I advise you to follow this link to know the compatibility between LabVIEW (and the run-time) and Windows : here.
Romain P.
National Instruments France
