Unable to load any 3D graph control for the provided examples
I have just installed Labview 8.5 and Diadem under a site VLM licence server on a new "virgin" XP laptop
I have previously do the same on a desktop one with trouble.
For this laptop, for all the examples of 3D graph display provided with labview 8.5,  all the controls "cannot be loaded" with sytematically an error 97 at the execution.
(2,488 Views)
Which OS are you using?
If you are using your VI as a subVI, are you including the “3D Surface” control reference to the front panel graph?
You can also try using the actual graph node that appears when you place the graph from the "Graph" palette on the front panel instead of the property node for the CWGraph3D.
Error 97 might also be caused by a missing or incorrectly located OCX file. It is preferable to link your code to the OCX file in the system32 folder.
Thomas Baudouin
Thomas B. | CLAD
National Instruments France
(2,453 Views)
