Unable to install Biomedical Toolkit and detection of Ventricular fibrillation
I have two question I am using labview version 2010(32 bit) but I am unable to install Biomedical Toolkit.It is installing but it doesn't appear in palette of labview (we are using a DAQS card) and my second question is that I have to monitor normal ECG and compare it with Ventricular Fibrillation so that We can turn on the Defibrillator. How can I compare this or what factors are required to compare?
(2,739 Views)
Hi medhat2010,
May I ask where did you get the Biomedical Toolkit? If you have download it here: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:pdl/q/Biomedical/ then it could be due to that you have installed the Biomedical Toolkit used for LabVIEW 2012 and LabVIEW 2013. During the installation, was there any option to select for LabVIEW 2010 support?
Do you have any LabVIEW 2012 or LabVIEW 2013 which you can use instead?
I did search in google. There is a Biomedical Startup Kit for this: https://decibel.ni.com/content/docs/DOC-12646
I'm not familiar with the ECG and Ventricular Fibrillation factors and what is to compare them. Sorry, can't help much on that.
Warmest regards,
Lennard.C
Learning new things everyday...
(2,714 Views)
