Unable to cast ActiveX object using "to more specific class". Error "polymorphic terminal cannot accept this data type".
I have a generic class that needs to be converted to a more specific class. I tried using the "to more specific class" node resulting in the error "polymorphic terminal cannot accept this data type".So i tried typecasting it, which seemed fine during edit time, but caused LABVIEW to crash during runtime.
Thanks Alot for the help (in advance :D)
(2,190 Views)
I'm sorry to say but you won't get any help with your question.  You gave us nothing to work with.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,169 Views)
Hello Aputman,
Sorry for that. I Will post the VI as soon as I can. Thanks for the feedback.
(2,165 Views)
Here is the code;I am trying to arrive at a more specific class.
(2,150 Views)
"To More Specific Class" doesn't work with Active-X references.  Just use "Type Cast"
(2,127 Views)
Thank you, but i have found the solution. It is to use the "variant to data" function like we would use "to specific class". The problem with type cast is that it crashes the entire VI.
(2,124 Views)
Typecast is definitely not the right thing to use for a refnum. There is more work to do in the background than just reinterprating the refnum as another wire type. There needs to be a real call to the ActiveX Dispatch mechanisme to retrieve the new actual interface that corresponds to the desired object and a Typecast won't do that.
The To More Specific class VI would be the logical one to use but that was only introduced in LabVIEW 8 together with LabVIEW classes while ActiveX exists since LabVIEW 4 or so. Apparently nobody has dared to touch the ActiveX code in a way to move that functionality to the To More Generic Class.
Rolf Kalbermatter
My Blog
(2,116 Views)
