Unable to capture data from Serial port using LVRT2010 in single core pentium 4 machine
I am using application written in Labview using windows Labview Runtime environment 2010. Application creates a tunnel to intercept data from Serial port.
My problem is, Currently, I am using single core Pentium processor. When I am trying to intercept the data between COM1 and COM7 (COM 7 is a virtual port) it is not able to capture data.
When I am running Labview RT environment using dual core processor machine it is running normally. I wonder whether it could be the compatibility issues with single core Pentium processor.
(2,594 Views)
Hi Magnetica
Are both of the machines running the same runtime engine, drivers ect?
Have you had RT applications running on this machine before?
Is the development computer a 64bit machine?
The processor is a supported model (See link below).
https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
Regards
Robert
National Instruments UK & Ireland
(2,564 Views)
